Fel Pro or Mahle the Mahle and VICTOR REINZ same manufacturer. Unfortunately things are not what they use to be. Fact remains you have to use a gasket,
I suppose if you clean surface good use studs cross for fingers the Cometics might work. MLS gaskets come on all the new Nissan's and that's all that is available, I have a 4.0 with 100K miles that hade never been hot but needed a rebuild. I hesitated but it's over 175 K today  no problem. No it's not boosted and is just SUV we use hard. One must be careful about counterfeit parts there e very where.
a 100 hp a cylinder can be made with 30 lb boost or 20 lb its not the  boost pressure that pushes the gasket
