Header Hdwr
hamer
pretty much figured that my car has Poston Headers on it with the stock Hdwr. THEY SUCK. what is a good grade of bolt to use in place of the old stock ones? Thanks
seriously? the hdwr from 1984. what are you using? size and stuff. Thanks
if i replace all the bolts will the oil dipstick tupe be a problem i know it rests on the stud but i wanna get some good hardware cause i got some copper gaskets comin soon. also should i use loctite on the bolt threads or not? ,Thanks
I didn't replace mine when I got the ATR headers. Just put 'um on the wire wheel and cleaned them up.
Here's a "no" vote for the Loctite but they may need a re-tighten after a bit due to heating and cooling.
Maybe you could take them to the HDWR store and match them up to new bolts if ya wanted (sorry) ;)
