Header panel removal instructions?
dataangel
I've done a few searches with little luck.
Does anyone have a step-by-step for taking off the header panel on an GN? I have the driver's fender skin off already, and I know about the the fender pins and fender stud. What all has to come off? Obviously headlight bezel / lights. . . grill? Anything else?
Thanks so much!
dataangel
go to gnttype.org they have REAL good instructions on how to get that out. Good luck!
Once you have all the nuts and bolts loosened up and you are ready to pull it off the car it's a good idea to take the headlights out first. The weight of the bulbs is enough to increase the likelihood of cracking the fiberglass. Been there - done that! Good luck.:rolleyes:
