headers
I should bolt right up. It probably won't work with the hotair crossover pipe, I think that's why I haven't seen any used on a hotair setup.
My car now has Postons headers, a Lee Thompson 3" downpipe, test pipe and 3" dual exhaust. What a difference over the stock junk! It definatly sounds intimadating :cool:
I just put an 86 drivers side manifold on my 84 T and it bolted
right up to my ATR hot air Crossover pipe. No problem anywhere.
The end points on the header are in the same place, so the fit
is the same.
Follow up to previous post. What is different
the oil dip stick tube won't fit the 86/87 header because
of the heat shields, so unless you knock off one of the heat shields, you will have to change to the 86/87 oil dip stick tube.
don't ask me how I know.
