Headliner fabric material is losing grip
Walt03
The gray headliner material is detaching itself from the sponge backing. This is occurring on both sides above the driver and passenger.
How do I fix this??
Walt
Replace it. Joann Fabric has the gray headliner material with foam backing. Gotta remove all the old off the headliner backing board first though. A brass wire brush works well but use a light touch. Once the backing board is clean, brush on Dap Contact Cement to the backing board only, let it get tacky for a few minutes, then lay the new fabric on starting on one side. A 2-liter Coke bottle makes a good rolling pin to press the fabric down evenly lengthwise from side-to-side. A little patience goes a long way here. Work outdoors; that contact cement has powerful, flammable fumes. You can get dizzy pretty easy from it.
Pain in the A$$ to do, but Jaxs has the correct fabric, 50 bucks or so, shipped. Nice people to deal with. Comes with fabric, adhesive, and instructions.
hth
