fast-turbo
- Oct 21, 2002
Hey I need help with my fan. My fan will not run at all. even if I turn the air conditioning on it still dosent come on. I just replaced the low speed relay and I'm wondering if i need to replace the other ones as well. The weird thing is that if i just turn on the ignition switch and bypass using a piece of wire on the diagostics plug it will run. I have checked all otf the fuses as well and there fine any help would be great.
Sorry i didnt replace the low speed relay i just replaced the coolant relay the big one. I did check the connections to the ecm and they are good should i replace the high and low relays just to be on the safe side.? Thanks for the help
