help help need advice on getting out the hole @the track
riviera
I went to track last nite my best time was and 8.25 @ 87 mph at an 1/8 mile track with 15lb.boost but everytime we leave the light the other car jump out on me I'm leaving on 8 lb of boof but its not enuff .now grant I can run them down but on an 8th mile track the race is over as soon as I get there look for some advice I have a t60 turbo with front mount inner cooler
These cars suck on the 1/8mile, theyr just gettin started at that point. if u want an 1/8 mile car put the stock turbo back on with very quick spool & 4.11 gears
My 60 ft was 2.18 my buddy has a monte carlo with 411 and his 60ft was 2.00 @buick gn3:16 I know because once I spooled up I was gone but he had the jump on me at the light
When exactly at the line do you start building your boost against the brakes?
2.18 what are you using for tires(psi, john force burn out, driving through/around the water?)
As turbo Dave asks when are you starting your boost build. You might need to start sooner and "bump" into the second light.
What torque converter are you using, stall speed(rpm)
You should be in the 1.8 range if they do a decent job prepping the track. And then into the 7s easily.
60'?
330'?
Your mph at 87 you are making the power. Just got to get it to launch.
I star boosting on the 2nd stage light I do my burn out in the water and I also have a line lock I have a 3200 stall non lock up conv. Aip pressur on street slicks about 30 lbs. I heat util I see smoke
i thin
i run 19# in my drag radials,any less gets loose at end.but in the 1/8 you might be able to go less.30# is way to much imo
thanks texas t im going to lower my pressuer on tires im nots sure how much bust i should try and build when i stage is 8 to 10 lbs average or less or more
Greeneyegi how much boost u leaving the line with wh iten u brake tork
i leave with 3-4# ,thats because my convertor,the best i got with that was 1.80 60'.thats also with a 28" tire,which ive been told is too tall for my hp level.
