Help ID this turbo, specs. inside:
NCTURBOS
Gettin' back in action!!
Staff member
I'm thinking it's a Te44...
Comp. wheel:
2.995"/76.07mm at the blades base
2.310"/58.67mm at the blade tips
Exh. wheel:
2.530"/64.27mm at the blades base
2.185"/55.50mm at the blade tips
TIA,
K.
The TE44 that we sell measures out like this:
Comp wheel:
2.290" Inducer
2.950" Exducer
Turbine wheel:
2.559" Inducer
2.228" Exducer
And just to throw this out there, our TE60 measures out like this:
Comp wheel:
2.320" Inducer
2.950" Exducer
Turbine wheel:
2.559" Inducer
2.228" Exducer
Now, way back when, we used to offer what was called a 6027 turbo.
It used the same compressor wheel, but used the T27 Stage 2 turbine wheel.
That turbine wheel measured:
2.559" Inducer
2.121" Exducer
So, if I had to guess, I would probably say it is a 6027 turbo as the turbine wheel measures closer to what you found. It was rated at 580 fwhp and was slightly quicker spooling than a standard TE60 turbo.
These measurements were taken at these points on this picture.
Hope some of this helps.
Patrick
Thanks Patrick... I'll measure a little more precisely this weekend, using your chart and #'s as a guide.
Thanks,
K.
