Help!! ID this turbo
pacecarta
LOGGED OUT
Staff member
I need help trying to ID this turbo
its has a 3" in 2"out garrett (M-43) TE style compressor housing
the exhaust is garrett .82 AR ,3 bolt
the compressor wheel is approx 58.8 mm at top and 74.8 at bottom (see pic)
the exhaust I didn't disassemble but its 58.3 mm at the housing (believe wheel to be 58 mm? at blade edges?)
never mind , found an old chart i had printed out
but its in inches
did the conversion
looks like its a TE44 but with garret housings
te 44 wheel specs are same as ta49
inducer (compressor side)
wheel diam. 44, wheel trim 60
2.290 (top) 2.950 (bottom)
turbine (exhaust side)
t31 style , wheel trim 76
2.559" inducer , 2.228 exducer
