Ok so I was setting my harland sharps on the engine stand. Primed the engine with a drill ( oil came out of the lifters just like it should ) and I was setting away and looked over and one that I had set just dropped. Hit the drill back up it went as soon as I stoped the drill back down it went. The weight of the pushrod alone is making it bottom out!
I didn't think a lifter should ever lose its prime?
Comp roller lifters.
Guess my question is should a lifter ever lose its prime after you prime the engine on the stand with a drill? I don't see how you could ever set your rockers if they did.
Let me know because im thinking these comp roller lifters of mine are junk.
