Help inside please
Sal Lubrano
My 1988 Delta 88 idle is high and I have a code 41. Which is a Cam sensor signal was not recieved by pcm for the last 2 seconds while engine was running. I changed the senor but nothing has changed. I reset the ecm and stil a code 41 keeps reseting. What to do next please. Thanks for an excellent boeard.
Sal
remove the cam sensor and look insde the hole while you turn over thr motor by hand. there is a magnet placed on the cam gear that falls off. make sure the magnet is there.
Thank you fellow members. As soon as I get a chance I will look inside for the magnet. Will let you kno if it is there.
