I just purchased 2 braces with hardware that I was told go from the oil pan to the frame rail. Does anyone have pictures of the braces installed that they could send to me?
*****NOTE, the note they say about "only fits with a stock intercooler is false. It only fits with a stock LOCATION intercooler. I have the BIG PTE and it fits fine. The frame braces will need moved slightly, if you have the big IC.
They don't go to the oil pan, and if they do... run. They should go from the frame horns to the crossmember under the engine. I'll try and find a picture for you
