help me decide on which turbo!
I am trying to make a decision on which turbo to get. Should I get the precision TA49 or limited engineering,which is the best.Please HELP!
turbo's are usually picked on horsepower goals,et goals,or budget,what are your goals and what is your current combo?
Do you plan on getting into heads soon? If yes, then the TA49 is too small. If your performance goal (long term) is mid-high 11s, then your fine. The difference between Precision and Limit Engineering is in the assembly. They both use garrett parts.
Hope this helps you,
