Hydroboost Conversion
Yes, The Pcv Valve Robs Vacuum From The Booster. They Must Come Off Of Separate Places In The Manifold. Electric Vacuum Pumps Are Noisy, And Usually Burn Up. Turbochargers Are The Opposite Of Vacuum, Since They Blow Air Into The Manifold. (the Whole Idea) But Vacuum Boosters Are Designed And Rated To Work At 20" Of Vacuum, Not 6". This Is Why I Recommend The Hydroboost. It Runs Off Of The Power Steering Pump Pressure. No Vacuum, And No Electricity Involved. The H/b Delivers Approx 2000psi To The Calipers. The Vacuum Booster With Low Vac. Delivers From 600psi To 900psi Depending On The Vacuum At The Time You Apply The Brakes.
