Help Need Pic Of Vac Lines
tnt
HI CAN SOME ONE SEND ME A PIC OF THERE VAC LINE, I SAW THE ONE ON THIS SITE BUT IT IS NOT REALLY NOT THAT GOOD CAN SOMEONE SEND ME A PIC ON YOUR FAN COVER THANK,S.
I tried the pic at night and the camera would not focus correctly on the vacuum line flow on the radiator cover. I also have a set of 85 manuals and could not find the right diagram(The manuals are are 18 inches tall. I will try a new pic tomorrow in the daylight, Brad.
THANK,S TO YOU ALSO BRAD I WILL CK OUT THE SITE TOMORROW GOOD NIGHT TO ALL.
Jerryl- I sent TNT a perfect pic which will help him alot. If he needs on the car pics I will send them as well. I do not want at all to hijack this thread but you may be able to help me alot. Send me an e-mail and I will ask the question and share my results on thi forum. Thanks- Brad
Brad_Padgett,
Can you also send me actual car pics of the vac lines. I cant seem to make out where some of the lines go on the sticky at the top of the page.Thanks in advance.
John
Yes I can and will do it. The pictures only work in broad daylight and are very helpful. I would like a little more detail on your question. Where is your pic needed? Thanks- Brad
wastegate to vac block and lines at rear of vac block (facing firewall) and where they go to also if you can from PCV to wherever they go pretty much all applicable vac lines if its not to much to ask. I really want to get the car going before the next GOODGUYS car show rolls along. Thanks in advance.
John
Jgines- Is the question about the vacume block on top of the throttle body with six vaccum (sp) lines coming into it? Do you have a stock waste gate act. or an adj. one? Thanks-Brad
Yes the vac block on the throttle body. I have the stock double line wastegate.
