Hey guys! I am having huge trouble getting oil pressure. I just put in a new oil rebuild kit with a booster plate.  I have filled the oil filter, and primed the lines. I have also taken out the cam sensor and manually turned the oil pump with a drill. Still none. Even tried backwards to pump it out with the cooling lines off. What do I do? Also, which oil cooling line should I use, top or bottom? I had my choice of pressure springs, but the 60lbs in, and then i switched it to factory. But there is one thing I did mess up though. When I recieved the booster plate, the directions gave me a templete to drill a 1/4" hole. Yea, it was for a 60's buick. But the hole sealed and soild through it. I dont see how if a 1/4" uneeded hole, can create no pressure. Any tips or tricks? This sucks!
Brandon
87 Buick GN
			Brandon
87 Buick GN
