EyeTalk2Trees
- May 29, 2001
Ok, the background, was running great and i got in and started it to leave. I forgot my phone and I turned the car off to unlock the door. I get back in 2 minutes later and it won't start. It turns over with the starter and trys to fire over (sounds like one or two cylinders fires) then it doesn't.
Trouble shooting: T-Link shows no codes so I Ohm'd the coil: 10 ohms front to back, looked at the Ignition module: no burning, or melting, or extra hard or soft. I checked the cam sensor and it is set correctly with correct voltage drop at 25degrees. I have 30# of FP when trying to start, and I have a steady strong spark. I even sprayed starting fuel in the trottle body with no results!!!!
It should start but it doesn't. I have fuel and spark at the right time, what could be the problem. I've checked all the FI and timing sensors they are good, how could it just not start....only hting i havent' checked it the computer, could it just...go out all of a sudden? How do you tst the computer? the car was running so great up untill I got in that last time...now nothing!!!
Help please
Help please
