Help! Rear Suspension Problem/ Ride Height
scot w.
GNSperformance.com
On my 86" GN the rear driver's side is about one inch lower than the passenger's side, I do have AIR-BAG'S what should I do to get a equal ride height???
TTT
Also with no air in the bag's the passenger side rub's with someone in the car, specialy with my wife and kid's(8 & 5) the right side would rub real bad here is my rear tire size P295/50R15 ??? thank you.
ride height
i have a brand new set of spring (for sale if you need them) the ride height was 29 inches from floor to top of wheel well with stock springs.
turbotoy
Re: ride height
turbotoy
The ride height on the drivers side is 27in. and 271/4 on the pass, side. are these springs veriable rate? and how much?
ride height?
What was the ride height from the floor to the top of the wheel well on the front? cause while I have the motor out i'll replace what I need to.
SORRY BRO DID NOT MEASURE THE FRONTS I HAVE MOROSO TRICK SPRINGS ALL THE WAY AROUND NOW AND THE WHOLE CAR IS IN THE WEEDS:D. THE REAR ON THE CAR NOW IS 25 AND THE FRONTS IS 24 WITH THE DRAG SPRINGS. I WOULD THINK IT WOULD BE LIKE 26.5 OR SO WITH STOCK SPRINGS.
TURBOTOY
question, do you have adjustable rear arms? if so then you may have a little preload in the rear making the right side sit higher. Not that thats a bad thing, alot of times you need to load them a little for launching straight. unless you have an anti roll bar.
if you are trying to keep it perfectly even and you do have adj arms just make sure you have a neutral bar when the car is sitting on level ground with the driver weight in the car.
ttt
No adjustable arm's, (stock) and a 3/4" sway bar that goes from one arm under the rear-end pumpkin to the other arm and it's bolted to both arms. is this the stock sway bar? don't forget my tire size is 295/50R15 REAR 165/R15 86T skinnies in the front.
most likely you have some sag in your springs which for looks isent a bad thing. what is your goals with it you want stock ride height or a lower firmer stance? if you want stock just replace with stock replacements if you want a drop i would rec. drop spindles and drop springs to give it the street ride that would be confterable and look good.
turbotoy
