My rear from my Grand National had been slipping and making noises so I took the differential apart and found my pinon shaft and spider gears worn and my clutch discs are pretty worn out. I want to rebuild it but the GM dealer says the parts are discontinued.
How do I get the parts to rebuild my posi or do I just have to buy an entire unit new?
Also I have already changed the pinion seal and pinion bearing but not quite sure I re-torqued correctly. Whats the proper step to secure the pinion nut?
