HELP! turbine housing needed
WarWagon
Caustic Cacophony
Hi Everyone
I bought a turbo without a turbine housing. I was told it was got a GN and everything is set up right like GN but it has a smaller turbine wheel. I can't find a housing tht will fit it. As far as I know it's a frankenstien turbo
"mish-mosh of parts", it does have a garret center section, airesearch compressor housing .70 a/r , roto-master compressor backing plate.
I measured inducer and exducer of the turbine wheel. HELP!!!!!
inducer 59-60 mm exducer 50mm
That's going to be a tough one. You might be better off calling Precision and asking to speak directly to Jim in repairs, with your measurements. He's probably the only one who would be able to tell you if they make a turbine housing that will fit/bolt on by simply asking you questions and for the turbine wheel measurements.
HTH
Patrick
alright thanks for your help if you helped
and it was a stock sized housing.
