Help! Tv cable and linkage.
Slick87gn
Finally decided to put in a shift kit. Chose BM. It came out without any problems. Took a lot oif digital pics. How does the bracket and tv cable hook onto the tranny . can anyone help. My service manual does not have any clear pics.
unhook the tv cable from the throttle body,
then un bolt the tv cable from the trans, 10mm wrench i beleive.
there is a hook that attaches to the tv cable from the inside the trans case, the hook is right inside the hole in the case.. just use some tweezers or something if your fingers wont get into the hole to grab it..
attach the hook and slide the tv cable back into the trans case and install the bolt
