Help!!! Vacuum Lines for CARBED Turbos
gchild1853
Hey everybody, i have a 83 regal t-type that i just got a few days ago and im trying to get everything back to original, and in working order. Im planning on replacing all of the hoses, and lines but i cant seem to find where the vac lines go... somethings the previous owner had blocked off ( a screw shoved in a hose very unprofessional) and im not sure if he knew what he was doing or what. The car does have a problem idleing in gear every once and a while, its better when warmed up but i still dont trust it, and im guessing its the vac lines. Ive also notice my idle air control doesnt move, and on the camaro i used to have i know it adjusted from the computer as it needed.... id REALLY appreciate it if someone could help me out with where all my vac lines went, and yes i have seen all the diagrams, and i dont know if im not very smart but they didnt help me ONE BIT!!! i need as much info as i can get... Thanks!!
The diagrams are what you would usually go by. There should be one on top of the Fan Shroud.
If you end up missing a few items let me know I have 3 83 t-types here.
Im gonna try to follow the diagram today and we'll see how far i get... i found an easier one to read... but you have all parts for these cars????
ok i cleaned it up... replaced all the vac lines, and then right when i was done... i looked over and saw a plug wire sparking... i moved the wire to a location where it was not near metal, and i took the car out ( i know i should replace the wires, im on it dont worry) it felt like a whole different car, it idled perfect, and it was a little wet out it lost a little traction at mid rpm... i felt the turbo smoothly and everything... im not sure if it was a combination of the vac lines and the wire, but now its running great...
Glad you got it running right.
I have had 7 83 t-types. We have alot of parts for those cars.
do you have body parts too??? i need the plastic pieces that go in between the bumpers and the body.... for the front and back, i also need emblems... do you have anything laying around that could help me out??? just let me know, im very interested
Yes I do. If you want just give me a call in the morning or e-mail me ith exactly what you need.
As far as the fillers we carry a full set with a lifetime warranty.
GBodyParts.com Online
