OneQuikSix
- Jun 7, 2001
I'm performing a leakdown test on my car and have tested each of the passenger side cylinders thus far. I'm not sure I'm doing everything correctly though. This is my procedure:
1. Engine hot
2. Move respective cylinder to TDC
3. Both valves closed (heads brand new BTW and recently back from good machine shop)
4. Pressurize cylinder using leakdown tool attached to shop air compressor
5. I open pressure regulator valve until leakage gauge reads zero/set and stop
6. Now, according to the instructions, I'm supposed to read the same leakage gauge for my resulting leakage for that cylinder.
On all three cylinders, I performed this procedure exactly as described. When the leakage gauge shows zero/set, the pressure gauge (0-100psi) shows 15psi for all three cylinders. The other thing that confuses me is I hear a steady current of air moving through the crankcase; which to me sounds like a blown headgasket.
This is a fresh rebuild and I don't think the car drives badly enough to have three cylinders leaking compression as badly as they are. The only path the air can travel with the valves closed is either past the rings or through the headgasket right? The car doesn't smoke and doesn't appear to be using water. I do notice what appears to be steam coming from the passenger side valve cover breather and was concerned enough to do this test for the first time.
Any ideas???
1. Engine hot
Any ideas???
