bmackinnon
- Feb 24, 2005
After reading the '180 Out' thread below, I got to thinking my cam sensor might also be 180 out. I have the motor at 25* ATDC, and have read the gnttype procedure(s). Question is... how the %$#% do you get to that bolt to loosen up the sensor?? Do I really have to remove the water line that goes to the front of the intake? Could some of you relate your method to getting that bolt?? I don't want to tear it apart any more than I absolutely need to, and draining water down wasn't something I was wanting to do. I'll do what's necessary, but just thought those of you that have done it 18 times might have a magic trick up your sleeve. I have a 14 mm combo wrench that I had to grind thinner on the closed end for something else that I'm thinking I might heat up and bend? Suggestions? Thanks!
