using a fast sytem bank to bank 160lb inj ran for a month testing in 10 frames per sec at 20 sec record using a labtop in car as well no data loger. did fine for awhil now it has deciced to record in frame 1 is .75sec frame 2 is 1.48sec frame 3 is 2.05sec not the usual 10 frames sec in my book and sometimes does not even get the fisrt 6-7sec of run just the shutdown of it.also the n2o enable has a major delay seems forever 2secs or more not instant like i want had to manually put n2o in to get instant hit running through relay as well. but it does pull the timing and put the fuel in when it hit the parameters. so why the delay and why does it not log like it did at first? can sent some attachments if someone want to see what i mean. plese help!!!!!!!
