Help with fouled plugs
HiTech6
I need some help with my car as it will black the plugs in 100 miles or less. I just put in a fresh set and took a 120 mile ride and came back and plugs were jet black. Car seems to run good with no issues. I have tried Autolight 103 and 104 plugs as well as NGK-7's. I do have Champion Alum heads and these are the plugs they recommended. I do drive this car almost everyday and I go race about once a month. Thanks for any help.
Fouled plugs
Thanks for the reply. I just checked and at 70 MPH my A/F was 13.9. What do you feel it should be? Thanks again.
That's not much info there.
Were you at WOT, or just cruising?
Anyway, I guess 13.5-14.5 is normal for just putting around town. Depends on if you are going up hill or ??
Are you sure it's not from oil?
I have about the exact same build up by the way.
Just about identical, except I have a T70 from Cotton, and a 212-218 roller
Fouled plugs
Thanks again for the reply and yes my car is using oil. Plugs do not smell gassed just very sooty. I was just in my driveway when I checked the A/F a couple of min. ago.
