Help with glove box lock
turbobuick
Staff member
I need to remove the lock for the glove box door. Does anyone know how this comes apart?
If you haven't figured it out yet, Ill try to explain a strange, to me, assembly. There is an access hole about an eighth inch in diameter, in the top of the door on the inside. Mine was plugged from the factory, with a filler to conceal it. Drill out the filler and you will have access to a metal snap ring that holds the two lock components together. Use a small diameter tool like an icepick to insert through the access holes and pry the metal ring off. The lock assembly will then come apart. HTH
MLH
Thanks, I tried that little hole with no luck. I ended up just cutting it out.
