Well it figures the car has been running great until I decide to go to the track.....then I get some issues....Lol
Here is the problem, I have noticed when driving on real hot day after the car is hot I have a small stumble when cursing 50-60 mph if you hold the throttle in a certain spot the car runs rough just like when you blow a boost line from the intercooler to the TB. As soon as you go past it clears up and no issues (again only when hot)
My initial thought was TPS so I double checked my settings .45volts at idle and 4.5 at wot....however I do get an offline reading when making a full sweep fairly fast but it only seems to occur at the 4.0 volt range
The other day I tried a soft launch cause I am getting ready for the Reynolds meet next month....I stalled the car a little and as soon as I lifted the brake I got a pop and a scan master reading of 101 mv and 31.2 degrees of knock.....it was only for a second I did not actually see the reading cause I was trying to keep the car straight.....but when I stopped I read the scan master......
So now I am trying to figure out if I need a new TPS?
when making a slow very slow sweep it shows to be good....but make a faster sweep I get an offline reading?????
Any ideas please toss them my way...
