help with turbo studs
crazygn
10's here i come
Does any one know what size studs are in the turbo on the up pipe side iam missing two of them and i cant get the ones out of my old turbo ,i could have my car running if it was not for the studs, do you think i can get them from a parts store or hardware store.
same problem
I have same problem with mine, was a real problem getting it out good luck! The studs you can get from the dealer.
hmm....I just use bolts in mine. Sorry can't remember the size but, they aren't anything special. Take the exhaust housing down to your local hardware and find some bolts that work, they might even have the right studs - if you wish to use studs.
If I was close to my car I'd go check the bolt size for ya. I can post them tomorrow if necessary.
HTH
Jeremy
