help
jack44130
Just installed new warbro pump and hot wire.now I cant get my pressure below 60lbs.I can blow through the return line,not blocked.I tried another regulator,same thing.Any ideas? Thanks Jack
How does the gauge react with and with out the vac signal on it?
What does the psi jump to with the prime from Key on no start?
Are you using and adjustable reg?
have 2 afpr, 1 bosch other kirbans,kirbans worked fine before pump change.now puts fuel out vac port.put bosch on, no fuel out vac port now.both reg.have 62lbs.on key turn on.can not adjust down.car loading up bad
just put stock reg.on it. now it has 65lbs.press.must be restricted return line.cant think of anything else.Thanks guys Jack
