Help!!!!!!!
How is it running , first i would check all the injectors and make sure that all the plug are on good, they might look like thereon but might not be on tight. Give them a good push and let me know .
when i put my motor in this happen to me.
Check your inj. wiring harness. If you have pinched a wire and put an inj. to ground, it could be staying open all the time. This would explain it running rich at idle, but not lean at higher RPM.
find meens of checking fuel pressure to see if pressure is changing with vacuum/boost or if the line on the regulator has fuel in it
also make sure you have vacuum at the regulator
