Help!!
Getemsuge87
I just recently purchased a 87 Buick Regal from Chicago I have little knowledge about the car I’m looking for a mechanic around the Houston Tx
Welcome to the dark side.
Welcome.
Nothing wrong with looking for help. I believe there are decent guys out that way.
My advice would be to search this site, gnttype.org, & vortexbuicks. To start getting knowledge & learning these cars as much as you can. It'll save you lots of time & money in the long run.
Welcome.
Car runs and idle fine it has some upgrades E85 and some other stuff. Back fire and misfire when I give it gas. Jus wanna find somewhere I can drop it off and pick it up once it’s done
You can also use the search & type on your issues. Pretty common with these cars. Could be ignition coil or module, fuel pump, etc.
I would definitely do the spring cleaning list off of gnttype.org, & if the car doesn’t have them already a Scanmaster(at the least), a fuel pressure gauge, & Hotwire kit.
I would think if the car is running on E85 you may prolly have all those items.
