Mr. T-Type
always broken
- Jul 23, 2002
Today I replaced my oil pressure switch and was driving home. I was boost and let off the gas and the car died. I started it back up and the oil pressure was around 5-6psi (normally 10psi at idle). I made it home (pressure normal when not idling) and checked for leaks and made sure I wasn't low on oil. Everything looks fine, but the car is only showing 5psi at idle. This makes me somewhat concerned. Any suggestions?
