Ok, i took the POS out for a test run today and it runs nice under 4000 rpm , it seems any thing over that and it back fires thru the down pipe real bad. I thought it was rich so i leaned it out and the same thing. I tryed one more time with the fuel press back up higher at 45psi vac off. This time it back fired bad and it seemed to have a bad mis all the way home , sounds like i lost a cyl or something.
I checked all my plug wires and there all on good, i do have a few little exhaust leaks but iam not sure thats it. It ran pretty good before i put the new parts on, this is what ive done since.
hooker headers
lt 3"down pipe
delta gate
kenne bell stall
moved the o2 sensor to the other side [drivers side header]
I'll pull the plugs and check them but other then that i have no clue.
i hate this car
hooker headers
lt 3"down pipe
delta gate
kenne bell stall
i hate this car
