how tired are you from all these power master q&a's?
Mine's been on the brink for awhile. sat in storage for some years, during which the accumulator bled down pouring fluid over the assy. started popping fuses. pump runs after one brake apply. now it can't keep a fuse at all.
in a moment of brilliance, I jumped the fuse with a momentary switch, trying to let the smoke out I guess. the pump strains to a hault just after the brake warning light goes out. ever heard of the actual pump rotor corroding/siezing? or could it all be the ball is requiring too much force to pressurize? went through the spec test when this all started, seemed kind of inconclusive.
also, still has an iron prop valve. is brass still available or still applicable?
props on the 200k milestone!
Andy.
Andy.
