trading t/a
I'm Angry!!!!!
- Aug 6, 2001
Had a slight exhaust leak(before the turbo) I fixed it checked for all other leaks(even blocked off all vaccum sources from the tb). BLM's never went below 160 with the leak 155 when the vaccum sources were blocked, fixed the leak now it sits at 128 but every few seconds it'll cycle to 160 then back down to 128 again(i assume when it cycles between open and closed loop. When it does that it stumbles at idle then when it goes back to closed loop in runs fine.
When i lock the chip into open loop it stays at 128, but the o2's never hit 500mv. they cycle between 150 or so up to 450. Haven't tried new o2 yet want to see if anybody else has any ideas.
I'm running an extender chip, msd 50's, pt-51 turbo, p&p big valve heads and matched intake, egr riser milled and filled, fp set to 45 psi(per the destructions that came with the chip
Looking for other ideas
Pete
![Big Grin :D :D](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
Pete
