Blown&Injected
- May 31, 2001
I am pretty sure I passed with the combo in my sig in the past, but this time I failed. I believe Maryland does/uses(?) the I/M 240 test.
HC = 2.5450 Cutpoint = 1.8000
CO = 12.3516 Cutpoint = 30.0000
NOX = 1.6462 Cutpoint = 2.8000
CO2 = 406.3211 Cutpoint = N/A
I am not happy with the O2 sensor, but it has not set any codes and the MAF has no screens - I am not sure I like the way that is working.
What can I do to pass?
I must say that the operator just stabbed the throttle when the car was to pickup speed and then right back to idle. So the car was just in a quick rev and idle situation for the entire test. Maybe 10% part throttle cruise, but really just a series of pops on the gas. The graph of the test results shows sharp spikes just at the beginning of every speed increase.
I must ask, even if I get no comment, what is clean piping/screening. I understand that there will be no comment on HOW to do it, I just never heard of it - sounds like dumping the exhaust under the car and pumping straight air in the pipe to the tail. If that is it, it sounds like more work than just fixing the engine!
THANKS!
THANKS!
