lotzagoodstuff
lotzagoodstuff
- Dec 19, 2009
So I have to get my GN Washington emissions tested. The car failed due to a high HC number at idle. The car is bone stock, sat for 4 years, had bad fuel pump, it has a new fuel pump, all fluids changed, fresh tuneup, and no modifications. The idle quality is a little lumpy, but it idles down to 450 rpms in drive as verified by the emissions machine. I did change a couple of vacuum lines that felt soft, and then I went around with some propane and checked all of the vacuum lines. I did notice when I unplug the EGR, it seems to idle better, which tells me that might be the culprit. Cracks me up that the numbers are so good at 25 mph on the rollers, but not so good at idle.
Here's all the data I got today:
HC CO CO+CO2 O2 RPM
CRUISE LIMIT 150 1 6 N/A N/A
CRUISE EMISSIONS 88 0.17 11.47 5.16 N/A
CRUISE RESULT PASS PASS N/A N/A N/A
IDLE LIMIT 220 1.2 6 N/A N/A
IDLE EMISSIONS 449 0.44 8.84 8.94 460
IDLE RESULT FAIL PASS N/A N/A N/A
Any input would be appreciated.
R. J.
HC CO CO+CO2 O2 RPM
R. J.
