Last night I installed a TE44 and Poston 3" 2pc downpipe (ported stock elbow), with a new oil line, drainback gasket, and composite 3-bolt turbo-to-header gasket.
I fired it up, and the idle in park/neutral was 2400 rpm, in reverse/drive was about 1200 rpm. Waited for about 20-30 seconds to see if it would drop down to normal, then shut it off. The only obvious leak (smoke) was maybe not a leak at all - just at the downpipe joint near the elbow, where I had put some ultra copper sealant.
I'm running a Thrasher, which normally idles at 650 rpm in drive. Also running an LS1 MAF and Translator. Also have a ScanMaster. I checked around underhood, I didn't see any obvious things (like vacuum lines unhooked, etc.)
The only thing I can think of is that I cracked the vacuum elbow which connects to actuator / turbo. Would a vacuum leak at this point, cause this?
Any ideas? Thanks,
Befuddled
![Confused :confused: :confused:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
Any ideas? Thanks,
Befuddled
