NitrousMan
- May 2, 2004
I'm looking at 2 87 GN's one with low miles 80,000 with a newer motor and trans with FMIC new ta 49 turbo but the car is pretty dirty for a the miles and it needs a paint job plus the interior is pretty rough and could use all new weather strips. The owner is pretty young and doesn't know much about GN's or what's been done to his car since most of the work was done by the previous owner. It does have aftermarket wheels that I don't really like but it has hooker exhaust and hooker headers. This car the owner doesn't have a list of all the mods done he could give me because he's not sure of everything.
The other GN has 152,000 miles on it but it has a 3 year old paint job that looks very nice with GNX flares, stock wheels and some mild mods to the motor with a stock turbo and alcohol injection and a rebuilt rear but the owner doesn't know if the motor or trans has ever been rebuilt but they are very clean. The current owner has owned it for a few years ans keeps it in the garage. He is the 3rd owner. The interior isn't perfect but it's clean and all the weather stripping was replaced in the last year. Here's a list of what this car has done to it:
Red Armstrong XP pump w/Billet regulator.
Cold air induction w/K&N filter
LT1 MAF w/Translator
009 42 lb. injectors
power plate
Progressive alcohol inj.(6 mos old)
F body radiator w/dual fans
3 in. Down pipe
Hooker Cat Back dual exhaust w/test pipe
New timing chain and gears
upgraded rockershafts w/LT1 comp cam valvesprings
Tubular lower control arms w/poly bushings
Eaton posi
Driver side airbag
pinion snubber
line lock
Vacumn brake conversion
Nitto 275 extreme drag radials
GNX flares
Direct Scan w/laptop
I'm kind of leaning towards the high mile car but should I be concerned about the miles since I'm going to use it for a daily driver? Both cars are Texas cars and have no rust. With a car with that many miles on it what should I look out for? Both cars are priced under $8,000.00. Thanks for any info.
power plate
3 in. Down pipe
Eaton posi
Driver side airbag
pinion snubber
line lock
GNX flares
