Today, I finally got remaining parts put in my car, I recently had broken the crank and then got a running motor and used the short block from that to put motor back together. When I plugged everything in, believe it or not the car started right up. Car ran at high idle, cycled ignition then it settled to 875. But two things are going right now, high oil pressure and motor heating up a little too hot. I shut it off at ~215(I'm going to investigate this one a little more myself).
Oil pressure is about 40psi at idle. I have a new sensor and the old bell looking thing that a ground wire is attached to. Baring it not being an issue with sensor, what are some other possibilities that could be causing it. This shouldn't make a difference, but I don't have engine oil cooler.
Thanks,
Charles
Thanks,
Charles
