TurboV6Sonoma
Im back!! Maybe for good
- Jan 24, 2005
* 70mm accufab throttle body and plenum with power plate $400.00
* MSD dis 4 ignition setup with buick adapter, with new coil pack and good ignition module. less than 500 miles never had a problem with it. $290
* stock exhaust manifolds welded and ported to felpro 1200 gaskets, ps header has a 1/8" hole drilled for a egt thermocouple. Also includes stock crossover $140.00
* Champion port and polished big valve iron heads under 500 miles $850.00 paid $1200.00 from Cal Hartline
* T&D roller rockers 1.65 $300
* Cottons single 3 inch exhaust with race magnum muffler and I will include a 3 inch TH dump. so this is a downpipe back exhaust system $225
* stock lower intake manifold $125.00
* voltage booster (I think it is a reds) It plugs into the alternator and a boost source. $20.00
* Accufab ajustable fuel pressure regulator. $60.00
* aluminum underdrive crank pulley. $60.00
* alternator underdrive pulley. $25.00
* billet thermostat inlet tube. $10.00
* stock boxed upper control arms. $20.00
* brand new stock type starter. $20.00
* stock fuel rail. $10.00
* seimens 72lb injectors. $270.00
* Steal braided Turbo Oil Drain Tube (from john performance). $25.00
* ATR stainless steel external wastegate downpipe. $175.00
pictures can be seen here>>>
http://community.webshots.com/album/363218832dgnYvK
