My GN does this "thing" at the top end of 1st gear, right before it shifts into 2nd, it gives a knock, kinda like a marble sound, just at this point, and at no other point across the powerband, except at the very top end, also there is no loss of power...Does this sound like bad news?...I was told that a new fuel pump, and fuel pressure regulator would take care of this, as well as using some higher octane gas...any idea's?!? The car is BONE STOCK, w/ 70K on it...Now, this only happens if I don't "let" the car shift, and I'm just flooring it, all the way up through the powerband. Of course, if I know when it needs to shift, I can tell, then it doesn't do it...any thoughts?!?
