Holley Dominator
oneg360
Super "Mario" Monjet
For the guys running Holley are you using a Hob Switch if not what are you doing to control dual fuel pumps?
As Chuck said, it's built in. One of the great things about using the aftermarket ECU is getting rid of extra stiff like a hob switch. I am using one of the outputs to trigger High speed on my brushless pump based on boost.
set it to +12v or Ground
map it to an output
