Re: Track times...
Here is the fun part! 105 mph is a 12 sec 1/4 mile.. You will get better times with slicks....15-16lbs of boost with a (92 octane) low timing chip could actually be turned up to 20-21lbs (turboBLUE 108). With your current minor problem
, I would bet the FARM
, you have yourself a 12:00/11.90 HOT AIR Intercooled Car.
Again Congrads...
Chuck MCCray
Originally posted by FJM568
Well, I went to the track last night...
My best time was a 13.619 @ 105.51 w/open dump
Now, before I hear WTF's, I just want to say it was a last minute decision to go, and I already had a full tank of 92 oct in the car already...So no race gas for me last night...I ran it just the way I drive it on the street...A low timing(I think it's an 18* chip, will check later today) Joe Lubrant chip, 15-16# boost, TA-51 turbo, CC206/206 cam, and street tires and some other stuff that I'm forgetting...Was having some problems with IC connections leaking, and really not having it tuned in...Right now, with the way my throttle linkage is set up, it ends up running right over the top of the fuel rail shrader valve, so it is nearly impossible to make any accurate fuel pressure changes(And right now, I don't exactly know what fuel pressure I'm running due to making a turn on the adj reg. while watching the scantool, so you're guess is as good as mine, initially before the TB relocation, it was set at about 44# on the initial startup when I got the car running again, so with the adj., I'm *probably* at about 42# right now)...
Also, my wastegate rod is too long(can't shorten it up any more(will fix that soon)...But I will say, that I wasn't getting any knock at all on the runs...Wasn't getting any traction, either feathering it off the line or getting wheelspin and letting off and then back in it...
So, all in all, kind of disappointed, but then again, kind of not, considering it was on pump gas, a low timing chip and low boost and almost no tuning...
edit...BTW, as soon as I get pics taken, I will be sending them out...
Again Congrads...
Chuck MCCray
