home built pan which filter 700r4
fastblackcar
Never Finished!!
im building a deep pan from two stock pans,i want to use a 700 filter, what vehicle do i ask the parts man for a filter for or advise me of a part # and what brand is best,do i just plug it in or will i need to do more? im cutting the pan from a stock pan and welding it on the bottom of another, any help would be great, im also adding a cooler thats 6" by 10" with a fan mounted on it will this be enuff? street driven car, where was that article on this two pans to make one, i thought i seen it on this site?
thanx
Tom
im interested in making one also, how deep does the pan have to be from the gasket surface to the bottom for the 700r4 filter to fit right and be held in?
Thanks, Dan
use an old detent lever bolted to a rear valve body bolt to hold the filter in place and insulate the filter from the 4th pressure switch .post some pics when completed.
any ideas on how to extend the filter downwrd more or does the 700 drop down farther in the pan
with an insulated connecter.the 4th switch shows ground until it shifts to fourth.if not seperated from the filter itll ground switch in fourth if the metal of the filter touches ground.
I just bought that filter (89 Iroc) and it's a drop in replacement for the 200, no pan mods needed. Mine is made by TransKing and has a part number of TK171 for anyone interested. Its backside is plastic so no worries about the switch contact either. I do see that it would benefit from an extension and a deeper sump though.
