Honda Trans Fluid?
tom j
I know its not a buick, but I just changed the fluid on the minivan (odyssey) and it was $7 a quart:eek: Whats so special about this fluid over the standard ATF?
The shifts will be much less firm if you use the standard ATF in the Honda instead of the recommended Honda trans fluid.
FACT: Honda DOES NOT make its own ATF fluid.
FACT: Consumers believe in Honda's marketing and swear that the special Z1 ingredient in Honda ATF is so exclusive... blah blah blah that your tranny would die with anything that is aftermarket...even if it is labeled Z1 compatible.
FACT: Honda's ATF additive package is supplied by NEWMARKET (NYSE: NEU) for OEM factory fill and service fill. This is also the same OEM supplier for GM's Dexron 6 ATF and Ford's Mercon LV, as well as supplier for Mobile, Quakerstate, Pennzoil, Castrol, Amsoil and Shell. It is a $1.5 Billion+ fuel&oil additive business. In fact, it developed these ATF for the auto manufacturer, hence the truth that autos don't make their own lubricants. There are a lot of industry open secrets and this is one that most consumers don't know.
FACT: It is OKAY to use aftermarket Z-1 compatible ATF. The only difference is IF you ever have a warrenty problem, you go to the oil manufacturer rather than Honda. I have used Castrol multivehicle ATF, Valvoline high-milage ATF and Mobile 1 ATF (new formula), all of which have specifically stated that they are Honda Z1 compatible in a late model 5sp-auto Pilot w/o any issues whatsoever! No funny shifts, clunks, shrudder, etc... In fact, these Non Honda fluids shifts silky smooth!
Aftermarket lubricants that are labeled OEM equivalent or compatible are labeled as such because of marketing agreements with the auto manufacturer. The autos own the exclusive trademark, therefore only HONDA can label its Z1 as genuine Honda and AC DELCO's Dexron 6 is genuine while the Castrol Dex 6 is just an equivalent or compatible fluid. The bottom line is that the same additive manufacturer supplies OEM and the aftermarket. If it says it is compatible then it is okay to put it in your slushbox. They do a lot of lab tests with real vehicles running on rollers all day long so they are experts when it comes to what works and doesn't work from your tranny to your fuel system.
FACT: Amsoil, very popular among some car owners, DOES NOT manufacture its own oil. It buys additive packages with the characteristics it wants and base oil from companies like NEU, and then markets its own blend as the best lube on earth :) It is able to make oil that exceeds most aftermarket oil because it overloads the additive packages so every bottle of AMSOIL lasts longer, runs cooler, less wear than even Mobile 1.
I did ask the counter guy at honda who makes there fluid and he couldnt tell me:rolleyes:
