Hood mount gauge brackets in stock!
TR Custom Parts
Mark Hueffman - Owner
Now have single AND double hood mount gauge brackets in stock. Powder coated steel set up for use with Autometer 2 1/16" #2204 gauge mounting cups. They have nut rivets installed so you don't have to struggle with wrenches while installing the gauge cups. Fits the contour of the hood nicely and screws to the flat surface under the hood. Holes are already drilled in the brackets for an easy installation. Not cheap but not cheaply made either.:smile: Made in the USA.
Hood Mount Gauge Brackets
Sweet:cool: Are the holes drilled to mount in the 2 holes already existing for the under hood light?
Didn't set them up that way but no reason it can't be mounted there. I prefer to mount it to the left a bit on my GN, seemed to work out better for hose/wire routing.
