I'm just curious to see what combinations work to make street tires hook at WOT (wide open throttle).
Does anybody use adjustable rear upper control arms to change the pinion angle of the rear end/driveshaft?
How about air bags? Do you need to put more air in one side than the other? How many psi usually work?
How about the No-Hop traction bars?
I currently have 15x8 weld wheels in the rear with 275/60/15 BFG Drag Radials and they just break loose when I stomp on it. I'm looking for a way to make the tires just hook and book. I'll be changing the wheels and putting on some 19" wheels with 275/35/19 tires.
