hoosier 28.10.5/15
sdteb
trying to get it like you
will this fit with out any modifications to the frame if not will 28/10/15 work?
thats what I had on the car but it depends on the back spacing! of your wheels. what wheels are you using the same ones that were on it? if so they will work. I can give you more info when we talk
didn't work for me
I have a set of 15x10.5 28 slicks on draglites with a 4.5 back space and they rub the frame i had a set or 28 x 9 slicks on a 3.5 backspace rim 15 x 8 and they fit fine
reply
like I said they rubbed against the frame I would need a notch to make them fit or could go with a spacer but thats a last resort
I have a set of 28x11x15 Goodyear slicks on a 15x10 rim 4bs Not one bit of
rubbing on the inside or outside still running fender molding also. ;)
